MeToo69
Message 11 of 102
Re: Home Hub 5 VPN issues after firmware upgrade
I have this issue too. Updated 2 days ago and this afternoon it all stopped working.
@BT what are you going to do about it, and how do I reinstall the previous software.
Tags (4)
Message 12 of 102
Have you tried a factory reset of the hub, to re-initialise the user config file. This can become invalid after a firmware upgrade.
liamh
Message 13 of 102
Yes, I did that earlier this afternoon. No change.
MeToo69
Message 14 of 102
apparently the software upgrade (well downgrade in this case) has blocked some ports used by the VPN software
Distinguished Guru
Message 15 of 102
But not on BT Wifi?
If not, I'll try again 🙂
liamh
Message 16 of 102
BT WiFi (aka FON) is not impacted, only the home WiFi is. Turning off the firewall doesn't fix it either.
MeToo69
Message 17 of 102
BT FON is a low capacity slow, and unrelieable connection and is not a solution
Distinguished Guru
Message 18 of 102
Very true, however it runs VPN on the same router the you say doesn't run VPN.
Distinguished Guru
Message 19 of 102
I have just dialled a L2TP VPN connection using my Homehub 5 running 204 with no problems 😉
19nbg71
Expert
Message 20 of 102
great!, you should be able to give him a hand with his vpn
