Showing results forΒ
Search instead forΒ
Did you mean:Β
Distinguished Guru
Message 21 of 102
Re: Home Hub 5 VPN issues after firmware upgrade
Give who a hand?
If not, I'll try again πŸ™‚
MeToo69
Message 22 of 102
Over normal WiFi or BTfon WiFi?
If over WiFi do u think u could be more helpful, and explain how ( and what you changed.)
If over BTfon, then that's not helping us at all
Distinguished Guru
Message 23 of 102
I ran it over a wired ethernet connection between my PC and the Homehub.
MeToo69
Message 24 of 102
Thats great, didnt work for me. What VPN software are you using coz if its not Check POint VPN-1 SecureClient Connection
then you dont have the issue we are reporting
Distinguished Guru
Message 25 of 102
No, I tested it using a VyprVPN endpoint using the Windows built-in dialler to setup a L2TP session.
It seems VPN works but Check POint VPN-1 SecureClient doesn't so I recommend you contact www.checkpoint.com for support.
MeToo69
Message 26 of 102
I believe there view is BT software had blocked ports the software uses. So they they not their problem. BT say nothing we've done (but of course it is)
Stalemate at the expense of the paying customers, FRANKLY IS TYPICAL
What ever happened to CUSTOMER SERVICE
Oh yes, those annoying customers, don't worry about them...
Andysedg
Newbie
Message 27 of 102
My hh5 updated to .204 on 20/1 - my son complaining GTA 5 on PS3 on longer working online - help he is driving me mad!
Distinguished Guru
Message 28 of 102
Have you tried putting the PC you are running Checkpoint on into the DMZ? There is a setting for that on the Homehub http://192.168.1.254/index.cgi?active_page=9112
MeToo69
Message 29 of 102
NOT an option due to the security implications
DMZ
Only one device, with either a static or a DHCP address, can be placed into the DMZ. The Hub will give it a private IP address and forward all appropriate traffic to this device.
Important: Placing a host in DMZ has significant implications for its security. Although it will be still located behind the Hub’s firewall ALL unsolicited traffic not rejected by the firewall will be sent to this host by the Hub’s Network Address Translator, increasing it’s vulnerability to attack
Distinguished Guru
Message 30 of 102
I suggest you do it just to see if it works.
