Message 41 of 102
Re: Home Hub 5 VPN issues after firmware upgrade
the reason i commented on the use of a residential line for business use is in breach of the terms and conditions you agree to on taking up your contract
Breed
Message 42 of 102
@john46 wrote:
you have a choice you can always use your own router you are not forced to use the home hub
True, but why should I have to spend my own money in order to do so? It's not like the Home Hub is technically incapable of it - it's just crippled by BT.
And in response to your post above, I re-iterate, I don't think connecting to a work VPN consitutes as buisness use. He's not a business, he's an employee working from a residence.
ray@ray_dorset wrote:
I have already demonstrated that VPN works fine with the new firmware
You demonstrated your L2TP connection works. We don't know what the OP is using. SSTP, PPTP, IKE? OP, is this someting you can supply us?
Distinguished Guru
Message 43 of 102
I already asked that but didn't receive the answer.
It turned out the problem wasn't with the VPN but with the client.
If not, I'll try again 🙂
MeToo69
Message 44 of 102
Does rayray_dorset work for BT, certainly seems like it Smiley LOL
Nothing that's been said so far actually helps unfortunately
Distinguished Guru
Message 45 of 102
No, not me. That's probably a different ray dorset.
liamh
Message 46 of 102
I'm using Check Point VPN1 SecureClient,  from what I can see in the config it's IKE over TCP?
Breed
Message 47 of 102
Indeed. The fact that it works for you over BT-Wifi/FON proves it is not a client issue. When you use BT-Wifi is creates a VPN to BT (in order to log who's connecting) so you're essentially creating a VPN tunnel inside a VPN tunnel, the Home Hub firewall can't see this so won't block anything.
Can you see anything obvious being blocked in the Firewall Event Log on the Hub? You also, liamh?
Distinguished Guru
Message 48 of 102
www.cindercone.com/data/VPNTroubleshooting.doc
liamh
Message 49 of 102
OK, I've set up the port forwarding using the default BT created rule for "Checkpoint FW1 VPN" and also a new "VPN" rule since the "Checkpoint FW1 VPN" one doesn't include port 18231 which is used for the policy update (the part that is failing).
Here's the log from my connection attempt that failed with the usual policy update failure:
10:29:12, 25 Jan.BLOCKED 4 more packets (because of ICMP replay)
10:29:11, 25 Jan.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 109.155.n.nnn-​>216.58.n.nn on ppp3)
10:27:55, 25 Jan.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.76]:18231 <-​-​> [109.155.n.nnn]:18231 -​ -​ -​ [198.199.nn.nnn]:48148 CLOSED/SYN_SENT ppp3 NAPT)
10:27:55, 25 Jan.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.76]:18231 <-​-​> [109.155.n.nnn]:18231 -​ -​ -​ [198.199.nn.nnn]:48147 CLOSED/SYN_SENT ppp3 NAPT)
10:27:54, 25 Jan.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.76]:18231 <-​-​> [109.155.n.nnn]:18231 -​ -​ -​ [198.199.nn.nnn]:48146 CLOSED/SYN_SENT ppp3 NAPT)
10:27:42, 25 Jan.(146388.180000) Port forwarding rule added via GUI. Service: vpn, protocol: TCP, external ports: any-​>18231, internal ports: 18231, internal client: duka6140
10:27:42, 25 Jan.(146388.180000) Port forwarding rule added via GUI. Service: vpn, protocol: UDP, external ports: any-​>259, internal ports: 259, internal client: dukaZZZZ
10:27:42, 25 Jan.(146388.180000) Port forwarding rule added via GUI. Service: vpn, protocol: TCP, external ports: any-​>259, internal ports: 259, internal client: dukaZZZZ
10:26:57, 25 Jan.(146343.210000) Port forwarding rule added via GUI. Service: Checkpoint FW1 VPN, protocol: UDP, external ports: any-​>259, internal ports: 259, internal client: dukaZZZZ
10:26:57, 25 Jan.(146343.210000) Port forwarding rule added via GUI. Service: Checkpoint FW1 VPN, protocol: TCP, external ports: any-​>259, internal ports: 259, internal client: dukaZZZZ
Distinguished Guru
Message 50 of 102
It says replay but it should say reply.
The message is "Host Unreachable" according to http://www.nthelp.com/icmp.html
