Message 1 of 4
Home Hub 6
Hi, when I open windows run and put in \\192.168.1.254 I get a Network Error saying cannot connect. I have connected an external hard drive to the router, Home Hub 6, and am trying to map it in as a shared drive. Any suggestions welcome. Thank you
3 REPLIES 3
Message 2 of 4
Re: Home Hub 6
Make sure you have SMB1 enabled on Windows, it is disabled by default
Anonymous
Not applicable
Message 3 of 4
Re: Home Hub 6
Just "Cannot connect" or something more detailed? Looks like there may be issues with the old SMB1 used by the Smart Hub unless they've been sorted in a firmware update.
Message 4 of 4
Re: Home Hub 6
Thanks, have turned SMB1 back on, still no luck. Also, when I have the external hard drive plugged in to the router and try to add a network connection, I get a message saying file not valid. Losing the will!
