j-whitney
Message 1 of 2
Home hub 3 time not updating
Hello, every since the clocks have gone forward the time on my router has stayed the same. Isn't it meant to auto update? I have tried restarting it and this doesn't help. The reason I'm asking about this problem is that it throws off all the other functions like power save mode by an hour which can be inconvenient at times.
___________________________
1 REPLY 1
spar
Message 2 of 2
Re: Home hub 3 time not updating
