Ecodragon37
Newbie
Message 1 of 8
Home hub 3
I have a home hub 3, it consistently drops connection, we have to turn it off and on again and this usually does the trick however sometimes this is 15 times aday, can any body help?
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Home hub 3
Hi @Ecodragon37 and welcome.
I'm sorry you're having problems with the connection dropping. Is this a wireless issue or does the connection drop on a wired connection? Do the hub lights change color?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Ecodragon37
Newbie
Message 3 of 8
Re: Home hub 3
It's a wireless issue, the lights do not change, everything appears normal except I keep losing connection and can only resolve it by turning the power off and on again
Moderator
Moderator
Message 4 of 8
Re: Home hub 3
Thanks for the quick reply @Ecodragon37.
Have you tried changing your wireless channel? How do I change the wireless channel on my hub will show you how. Can you try that and let me know how you get on?
Cheers
David
Kudos”Kudos”
Ecodragon37
Newbie
Message 5 of 8
Re: Home hub 3
That link is for a view box
Moderator
Moderator
Message 6 of 8
Re: Home hub 3
My mistake @Ecodragon37 Smiley Embarassed. Can you try that?
Cheers
David
Kudos”Kudos”
Ecodragon37
Newbie
Message 7 of 8
Re: Home hub 3
Will give it a go and get back to you
Moderator
Moderator
Message 8 of 8
Re: Home hub 3
Hi @Ecodragon37,
Did changing the wireless channel help? Can you let me know how you're getting on?
Cheers
David
Kudos”Kudos”
