feegee
Message 1 of 4
Home hub 4 query
Hi, with regards to the lights on the HH4, when i am using data, is the blue light supposed to flash ?
The reason i ask is because i have been having issues with my data usage (which is being looked at by one of the mods) but for the last few days i have noticed that the blue light on the hub is a static blue and i'm pretty sure that in the past i have noticed it flashing when i'm using t'internet ....... i could be wrong of course but hopefully someone can clarify my stupid question.
Many thanks : Fee.
3 REPLIES 3
Checked2013
Expert
Message 2 of 4
Re: Home hub 4 query
If everthing is okay then it should be a solid blue
feegee
Message 3 of 4
@Checked2013   Thank you very much for your quick response. Maybe it was just a glitch when i saw it flashing.
Message 4 of 4
