Amanda3
Newbie
Message 1 of 2
Home hub manager
Have asked BT and they havent been able to help so far.
I cannot get my hub manager to save my devices separately to restrict different times on each. It says it is saving but is then deleted from the list and times arent changed or device even added..any advice welcome
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Home hub manager
Try doing a restart of the hub
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
