Message 1 of 5
Home hub won't connect after moving house
Hello All,
I've recently moved house and have arranged for my internet to be reconnected on Monday. On Tuesday I received a text saying "Hello, BT here. Your broadband and phone services are now ready to use. Need help getting started? Go to bt.com/newtobt".  This turned out to be incorrect.
It is now Wednesday morning and I am still being greeted with an orange light as well as a flashing red thingy. All the online steps just move you around in circles without solving anything and it appears to be impossible to get a hold of a human being on the phone.
Has anyone got any suggestions how to proceed? I feel like there is potential that I am being really thick and am overlooking something but I'm not sure.
thanks!
4 REPLIES 4
Message 2 of 5
Re: Home hub won't connect after moving house
Do you have dial tone?
Is it the correct number read back to you if you dial 17070?
Message 3 of 5
are you using the master socket and not an extension socket?
Message 4 of 5
Hi thanks for your response, I am using a extension socket (Adsl filter). I don’t have a phone so can not check the dial tone. The WiFi network is visible on my laptop
Message 5 of 5
Re: Home hub won't connect after moving housen- Solved
I've solved this issue, my new portal thingy in the wall has two ports so i didn't need the filter. Thanks All
