Message 1 of 7
Home page
Window 10, MS Edge.
Two home pages open each time I open my browser.
Advice please?
6 REPLIES 6
Message 2 of 7
Re: Home page
does it happen when using chrome?
Message 3 of 7
Re: Home page
Running the latest version of MS Edge/Windows 10/2004.........this did happen a while ago and having just reset my Windows 10 installation it has reappeared.
Sadly I can't remember the very simple answer!
Message 4 of 7
Re: Home page
Check the browser startup settings, it may be configured to open multiple pages on startup.
Message 5 of 7
Re: Home page
Using Edge: try the following,
Go to settings >  history > manage history > clear history items in the listing individually.
Then close tab - history at the top ( there will be two tabs at the top..you need to close the right hand tab).
Click on the home icon for the remaining  tab. This should now give you your selected home page.
Message 6 of 7
Re: Home page
Start you browser and go to the settings (found by clicking on the three dots top right corner) then go to "On Start Up".
It will show what pages are set to open when the browser opens.
If it is set to "Open a specific page or pages" make sure it is only opening the page you want and and not two of the pages.
Message 7 of 7
Re: Home page
Thank you all.
"Open a specific page or pages" Resolved the issue.
