dikul
Message 1 of 3
HomeHub5b - any upgrades?
Whilst my Smart Hub never actually died on me, it's performance was a little sporadic, so it now sits in a cupboard gathering dust.  Since May my trusty 5b has been doing sterling work, even if the wifi is weak, giving me a rock steady 56 Mbps download speed.  I have just noticed a firmware upgrade for the 5a is being rolled out, are there any plans for an upgrade to he 5b?
2 REPLIES 2
smf22
Recognised Expert
Message 2 of 3
Re: HomeHub5b - any upgrades?
I connected my Hub 5B again recently when lighting took out my OR modem and noticed that it booted after the first night of being connected and changed firmware from v0.07.06.09028-BT to v0.07.06.01239-BT.
The 01239-BT release has been around since Jan/Feb 2017 with some debate in New HH5B update, version number lower than the old... and New HH5B firmware update, or a revert? as to why the release number of the 'newer' firmware was lower.
What version do you have at the moment?
dikul
Message 3 of 3
Smr22
yes I have the same version as you, so at least I know I'm up to date, thanks.
