Newbie
Message 1 of 1
Homehub 5 will not open some ports
Hi
Driven myself mad.
Have been using an HH5 for a long time. Have lots of devices controlled by and connected to it.
Have several ports forwarded for internal and external access.
All works fine so think I know what I am doing
Need to open a specific port - 9001 - for local use
Open the port by forwarding 9001 to 9001 - is there another way to open a local port?
HH5 says it is open
Browse to it, connection refused
Turn off Firwalls on computer, HH5, disable anti-virus - no difference, cant browse to that port
Is there something special about that port? Is it reserved for some reason?
Have rebooted Hub numerous times
All help gratefully received before I go nuts
thanks
