jimmehr
Message 1 of 6
Homeplug adapters are running slow.
I am currently using 200Mbps homeplug adapters to connect my PC to the internet.
My Infinity connection runs around 30-35Mbps Down and 6-7Mbps Up
However for some reason my Homeplug adapters are running around 2Mbps down and 6-7Mbps up.
The software says the homeplugs are running at 147Mbps.
Ive tested my PC downstairs connected to the homehub and the connection runs around 30-35Mbps down and 6-7Mbps up
Anyway on getting the homeplugs to work properly or should I just put up with it until payday and hardwire it up.
5 REPLIES 5
Message 2 of 6
Re: Homeplug adapters are running slow.
You plugged anything new into your mains recently?
If not try rebooting the home plugs 🙂
Distinguished Guru
Message 3 of 6
The speed you get through homeplugs can be quite variable, depending on the state of the wiring, where they are plugged in, and quite possibly what else is pluggen in nearby.
Mine give a pretty poor speed, but adequte for BT Vision, because they are on separate rings, even though they are on opposite sides of the same room.
jimmehr
Message 4 of 6
The only new thing which has been plugged in, is the openreach modem and that is plugged in next to the adapter.
They both have been rebooted and they are now running about 5Mb down and 7Mb up.
Before switching to infinity they where going around 95Mbps on local traffic and the internet at max speed which was 7Mbps down and 865Kbps up
Message 5 of 6
Surely you have more than just the openreach modem plugged into your mains!
Anything on the mains circuit could be affecting them. Heck, something your neighbour has plugged in could be the cause.
jimmehr
Message 6 of 6
The openreach modem was the newest item to be plugged into the mains,
Everything which was plugged in before switching to infinity was stilll plugged in,
I've given the homeplugs are full reset and set them back up again now I am getting the full 32ish Mbps now 😄
