Message 1 of 2
How can i get a static ip on my ps5??
Hello, how do i give my PS5  a static ip using the bt hub manager?
1 REPLY 1
Message 2 of 2
Re: How can i get a static ip on my ps5??
That is an oxymoron, by definition you can only give a device a static address on the device itself.
You can, however, use address reservation. Just tick the 'always use this address' in the hub manager advanced settings.
