maxima
Message 1 of 3
How do I access my home computer remotely if I have dynamic IP ?
I sometimes need to get remote access to my home PC (when I am on long holidays).
I had static IP from BE for years and never bothered to look around.. I know there is a thing called dynamic DNS. But from what I understood is that my router needs to support it.
I had TP-Link which had native support for few Dynamic DNS services. But the BT HH5 - I dont see it anywhere.. Looked on the web - people say the access is intentionally disabled..
So my question is - whats the easiest / cheapest way to access my PC without knowing the current IP address of the HH5 ?
(I dont need it often - may be a dozen days a year but this must 100% reliable - I work from home so if I need to access it it has to be done, otherwise I might as well break the holiday and fly back)..
2 REPLIES 2
Message 2 of 3
Re: How do I access my home computer remotely if I have dynamic IP ?
You can not get a static IP address on a BT residential package. Have you thought about using one of the web based sites such as LogMeIn.
Message 3 of 3
Its actually quite easy to do, even on a dynamic IP address.
The HH5 supports DynDNS and a couple of others. Look on the hub help pages under Dynamic DNS.
If you need more help, then let me know.
