Message 1 of 7
How do I add a security camera to my BT hub2?
Do I add a security camera to my BT hub2?
The camera is Tapo C200
6 REPLIES 6
Message 2 of 7
Re: How do I add a security camera to my BT hub2?
Just follow the Tapo instructions. Probably need to use the Tapo app to connect camera to hub wifi
Message 3 of 7
I wish I could , can't make sense of them
Message 4 of 7
Did you install app on mobile?
That should then guide you to connection
Message 5 of 7
Yes. @imjolly
I get so far, then I get a message about reset - then it tells me it's already reset, then it falls over.
I will post some images on here tomorrow, if I can.
Thanks for the help to this point
Tags (2)
Message 6 of 7
Have you tried watching the setup video at Download for Tapo C200 | TP-Link United Kingdom
Message 7 of 7
Now sorted.
Once I managed to get camera connected to router, all went well.
Thanks all.
