Icedragon05
Message 1 of 2
How do I connect a powerline 500 to bt mini hub adapter
I have the new smart hub with an older Mini Hub and a Broadband Extender Flex 500 Kit . both the mini and the 500 are currently cionnected direct to the smart hub by ethernet to their respective adapters. Is there an easy way to use just one adapter for both mini and 500?
1 REPLY 1
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: How do I connect a powerline 500 to bt mini hub adapter
Hi @Icedragon05, yes that should work.
I suggest you leave the Mini Hubs as they are, and you unplug the Flex 500 from your Hub.
You then need to pair the other Flex 500 to the Mini Hub left in the back of your Hub. There's a button combination described in the user guide to enable pairing on those devices (something like long press on the link button of one, then the other). I don't have it at hand, but if you can't find it, come back here and someone will no doubt help.
