ljm
Expert
Message 1 of 5
How do i disable Wifi
Hello,
Please could someone give me a link to the page where i can make Wifi disabled?.............. it's suddenly become Active again since ive done  Factory Reset.
4 REPLIES 4
Message 2 of 5
Re: How do i disable Wifi
ljm
Expert
Message 3 of 5
Thanks licquorice!!
Message 4 of 5
If you still have problems.
If you try opting in first, then wait 24 hours, then opt out again. That will be seen as a change of state, and the opted out configuration should be sent to the home hub.
Bear in mind, any factory reset of the home hub, will re-enable BT Wifi, and you would have to do the same thing again, as it would be unaware of the reset.
ljm
Expert
Message 5 of 5
Thanks Keith for that!
