I’m trying to set up a near work so my Bose speaker can be found with my SmartThings hub, the hub is wired to the router and the speaker is Wi-fi, if I plug the speaker in via cable the hub finds it
If your speaker has a WPS button try pressing it. Then press the WPS button on the hub. The speaker should then connect to your WiFi
(If I have helped you in any way please click the thumbs up. Thank You) If I have solved your Issue please click the "Mark as accepted solution" button.
