Message 1 of 9
How to get tech advice as modem not connecting?
Have spent 5 evenings trying to contact tech support as advised by online chatbot after message received stating ‘unable to get serial number from open reach modem’ .
Recommendations for being able to get through welcome please
8 REPLIES 8
Message 2 of 9
Re: How to get tech advice as modem not connecting?
There’s something fishy about that message.  The “modem” is called an ONT or Optical Network Terminal.  Openreach would not refer to it as a “modem”, so are you sure the message actually came from Openreach?
Message 3 of 9
Do you actually have a problem with your service?
Message 4 of 9
Thanks, yes believe so, may have been my recollection of what it said that is incorrect but thought that was what I noted down
Message 5 of 9
Hub just keeps flashing green light and not connecting but apparently no issues with local cover
Message 6 of 9
Hub flashing green is when it is booting up. Sounds like possibly a faulty hub, power it off for a few minutes and try again. If it still flashes green report the fault to BT 0330 1234 150
Message 7 of 9
Thanks, have tried this as per Guidance offered when trying to contact BT, no joy, still flashing green light. Have tried reporting fault on that number several times but frustratingly no success getting a response.
Message 8 of 9
This is just a customer to customer self help forum, you need to persevere with that number.
Message 9 of 9
Which hub? If you mean the PON light on the ONT is flashing (white Openreach box on the wall), it’s either not registered, has a high light loss reading, or there is a network issue that needs resolving. The serial number the CP is after is the one with the bar code.
