IeuanG
Newbie
Message 1 of 6
How to obtain a new public IP address
I have a BTHomeHub 2.0, and am wondering how I would obtain a new public IP address. I have not asked for a static IP address, and it seems strange to me that BT has seemingly assigned me one. I have had the same IP address for over 2 years now, and although it may seem like there is nothing wrong with having the same address for a long amount of time, it does get tiresome. Is there any way I can obtain a new one?
Thanks, IeuanG
5 REPLIES 5
Message 2 of 6
Re: How to obtain a new public IP address
Got to be a troll, don't know why I'm replying really.
You don't get a static IP address, I seriously doubt you have had the same IP for 2 years (how do you know) and even if you have, why would you want to change it.
barnpiece
Expert
Message 3 of 6
If you disconnect and reconnect to the internet I think you should get a new one.
Have you tried rebooting your hub?
Richard
IeuanG
Newbie
Message 4 of 6
I'm a webdev / sysadmin for a few small sites, so I generally run small test servers from home. I also remote into my pc occasionally, so I would know it through that.
IeuanG
Newbie
Message 5 of 6
I believe I have tried that already, but I will double check for troubleshooting 😄
IeuanG
Newbie
Message 6 of 6
I can't believe it, this finally worked! Guess there was something wrong last time I tried this, wow!
