Message 1 of 3
How to prioritise voice QoS on BT smart Hub 2 for Wi-Fi Calling
How do you do it?  At the moment other devices that use UDP e.g. ring doorbell just knock out the UDP packets from Wi-Fi calling rendering it useless.
2 REPLIES 2
Message 2 of 3
Re: How to prioritise voice QoS on BT smart Hub 2 for Wi-Fi Calling
Simple. You can't.
Message 3 of 3
That effectively makes WiFi calling useless if you happen to have other devices on same WiFi channel that e.g. stream video using UDP such as a ring doorbell
