Message 1 of 5
How to turn off hot spot?
For some reason my HH 6 (smart hub) has suddenly enabled hot spots.
There is a link from the HH to go to a BT site to disable it unfortunately it does not recognise either my primary email login details or my BT ID.
I need to disable it as the additional signal strength on 5Ghz prevents the mesh working on my Sky Q set up. I have overcome this by turning off  5Ghz, not the ideal solution.
Can anyone suggest a way of turning hot spots off.
4 REPLIES 4
Message 2 of 5
Re: How to turn off hot spot?
Turning off the hotspot will make no difference, it just uses the same WiFi signal as your own network, just a different SSID and routing.
Message 3 of 5
Hi @Bob1001
Go to the My BT website and log in. You should find the Opt out of BT WiFi by selecting My Package, Manage Extras.
Message 4 of 5
That may be true in theory however with it on it effects my Q mesh by swamping it, with it off I have no problems.
Message 5 of 5
@VeteranISPUser  Thank you.
