robneil
Newbie
Message 1 of 1
Hub 3 connected to Airport wireless bridge
Having severe problems with a Draytek 2850 all of a sudden, so looking at a quick and dirty fix.
Scenario:
Router --> Apple Airport extreme #1 <----> Apple Airport extreme 2 --> switch --> servers & PCs
The 2 Airports are running an 801.11n wireless bridge, all currently on a 10.0.x.x range, with SSID_1 being broadcast
Now, I know that normally you have to plug stuff in to the BT hub to enable port redirection and so on, but will this scenario work if I swap out the existing router for the BT business hub 3? That is, will the stuff on the other side of the bridge be detected?
TIA
