djh22
Recognised Expert
Message 1 of 3
Hub 5 Wifi light
Hi, I've disabled all wifi on my Hub 5 but notice that the wifi light is now on constantly, before disabling wifi the security was set to WPA2. Any ideas what would cause this please ?
Ta,
Del.
2 REPLIES 2
Message 2 of 3
Re: Hub 5 Wifi light
the Wi-Fi light will be on all the time to advise you that the wireless is turned off
djh22
Recognised Expert
Message 3 of 3
Oh right , I would have thought it to be the other way 'round  Smiley Wink, you can tell I've been away from BT for a while.  Smiley Happy
Thanks for the info John.
Del.
