Charley_Lima
Message 1 of 5
Hub 5 problems
Recently received a Hub 5 with a new contract and have a number of issues.
First, in order to resolve 5ghz problems needed to restart router and found that printer [wireless] needs full configuration. With my old Hub 2, if there was a power cut or a router restart, the system remembered the settings - any fix?
I appreciate that the range using 5ghz is limited - but how limited?  Is it possible to disable 5ghz? If so, how?
Find that web pages often report connection problems with Hub 5 that didn't happen with Hub 2.
Thanks for any help
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Hub 5 problems
Hi Charley_Lima,
Thanks for posting. Take a look at I have problems connecting 5GHz and dual band devices wirelessly to the BT Home Hub 4 or Hub 5. Let me know if that helps.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Charley_Lima
Message 3 of 5
Re: Hub 5 problems
Thanks David
That sorts my wife's iPad connection problems and would assume she is back to 2.4ghz
Any thoughts on points 1 & 3 ?
Message 4 of 5
Re: Hub 5 problems
Make sure that you have "Smart Set Up" turned off on the Homehub. It can cause problems with devices that can not acknowledge it.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
I think you may have done this but if not try giving the 2.4Ghz and 5Ghz frequencies different SSids. Just add a 5 to the end of the 5Ghz SSid so you know which is which. Check the 5 GHz Sync with 2.4 GHz: is set to NO.
Once you have done that "forget" the connection and then restart your devices and log onto both. The device should then automatically switch to the strongest signal. Keep in mind that the 5GHz signal has a poor range of only tens of meters and that can be affected by walls etc.
See this link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
You should also turn off "Smart Wireless" and give your router a fixed channel.
See Link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/14094/~/how-do-i-change-the-wireless-channel-on-my-bt...
If you download and install inSSIDer which is a program that will scan for and show wireless networks and show you which one is least used and has the strongest signal.
See link for inSSIDer
http://www.techspot.com/downloads/5936-inssider.html
Charley_Lima
Message 5 of 5
Re: Hub 5 problems
Many thanks
Not that impressed with ' inSSIDer' !
"Your link score would improve by moving to Channel 6"
I change to 6 from 1
"Your link score would improve by moving to Channel 1"
will soo how things setle down.
Only real annoyance is that printer is not saving connection - after restart or power cut - I have to reconfigure wireless connection
Regards
