m0sbf
Message 1 of 20
Hub 5B re-boots every 4 to 5 days
I am trying to get to the bottom of why my Home Hub 5B re-starts every few days. I am trying to get my line speed unbanded and the constant periodic re-boots from the router aren't helping as the DLM counters keep getting reset.
I'd appreciate it if someone could take a look at this event log and offer any advice/help. The router restarted at around 13:08 today, with no user intervention.
I have a Home Hub 6 on the way, so may try that to see if it is more stable.
13:14:30 03 Feb. Receive a DHCP request
13:14:29 03 Feb. Receive a DHCP request
13:13:38 03 Feb. Device Connected: 192.168.1.92 88:c6:63:88:c3:0b Steves-iPod
13:13:38 03 Feb. DHCP Lease issued 192.168.1.92 to 88:c6:63:88:c3:0b Steves-iPod lease duration is 86400 seconds
13:13:38 03 Feb. 2.4G Client associate from 88:c6:63:88:c3:0b (IP=192.168.1.92) RSSI=-73 Rate=19Mbps host Steves-iPod
13:13:36 03 Feb. Receive a DHCP request
13:13:17 03 Feb. Device Connected: 192.168.1.86 cc:3a:61:5b:34:04 android-ef6a34cff30cc76a
13:13:16 03 Feb. 2.4G Client associate from cc:3a:61:5b:34:04 (IP=192.168.1.86) RSSI=-64 Rate=65Mbps host android-ef6a34cff30cc76a
13:13:15 03 Feb. Receive a DHCP request
13:12:15 03 Feb. Device Connected: 192.168.1.245 8c:fa:ba:a9:a1:31 Steve-iPad
13:12:15 03 Feb. DHCP Lease issued 192.168.1.245 to 8c:fa:ba:a9:a1:31 Steve-iPad lease duration is 86400 seconds
13:12:15 03 Feb. 2.4G Client associate from 8c:fa:ba:a9:a1:31 (IP=192.168.1.245) RSSI=-63 Rate=58Mbps host Steve-iPad
13:12:14 03 Feb. Receive a DHCP request
13:11:39 03 Feb. CWMP: HDM socket closed successfully.
13:11:38 03 Feb. CWMP: HTTP authentication success from pbthdm.x.x.x
13:11:38 03 Feb. CWMP: HDM socket opened successfully.
13:11:38 03 Feb. CWMP: session completed successfully
13:11:38 03 Feb. CWMP: HDM socket closed successfully.
13:11:37 03 Feb. CWMP: HDM socket opened successfully.
13:11:34 03 Feb. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
13:11:34 03 Feb. CWMP: Session start now server: pbthdm.x.x.x Event code:
13:11:34 03 Feb. CWMP: Initializing transaction for event code 4 VALUE CHANGE
13:11:26 03 Feb.  2.4G WiFi auto selected channel 11 Bandwidth:20M(Reason:boot)
13:11:21 03 Feb.  2.4G WiFi scan(Reason:boot)
13:11:20 03 Feb.  5G   WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
13:11:15 03 Feb. CWMP: HDM socket closed successfully.
13:11:15 03 Feb. CWMP: HTTP authentication success from pbthdm.x.x.x
13:11:15 03 Feb. CWMP: HDM socket opened successfully.
13:11:14 03 Feb. CWMP: session completed successfully
13:11:14 03 Feb. Device Disconnected: 192.168.1.86 cc:3a:61:5b:34:04 android-ef6a34cff30cc76a
13:11:14 03 Feb. CWMP: HDM socket closed successfully.
13:11:13 03 Feb. CWMP: HTTP authentication success from pbthdm.x.x.x
13:11:12 03 Feb. CWMP: HDM socket opened successfully.
13:11:12 03 Feb.  5G   WiFi scan(Reason:boot)
13:11:10 03 Feb. Device Connected: 192.168.1.170 28:37:37:ba:6d:16 Kims-iPod
13:11:06 03 Feb. 2.4G Client diassociate from cc:3a:61:5b:34:04  (IP=192.168.1.86) RSSI=-64  Rate=58 Mbps
13:11:05 03 Feb. Receive a DHCP request
13:11:04 03 Feb. CWMP: Server URL: <removed before posting> Connecting as user: ACS username
13:11:04 03 Feb. CWMP: Session start now server: pbthdm.x.x.x Event code:
13:11:04 03 Feb. CWMP: Initializing transaction for event code 1 BOOT
13:10:59 03 Feb. Device Connected: 192.168.1.242 64:20:0c:35:55:f2 Kids-iPad
13:10:58 03 Feb. DHCP Lease issued 192.168.1.242 to 64:20:0c:35:55:f2 Kids-iPad lease duration is 86400 seconds
13:10:58 03 Feb. 2.4G Client associate from 64:20:0c:35:55:f2 (IP=192.168.1.242) RSSI=-52 Rate=65Mbps host Kids-iPad
13:10:56 03 Feb. Receive a DHCP request
13:10:47 03 Feb. Device Connected: 192.168.1.86 cc:3a:61:5b:34:04 android-ef6a34cff30cc76a
13:10:46 03 Feb. NTP synchronization success
13:10:46 03 Feb. DHCP Lease issued 192.168.1.86 to cc:3a:61:5b:34:04 android-ef6a34cff30cc76a lease duration is 86400 seconds
13:10:46 03 Feb. 2.4G Client associate from cc:3a:61:5b:34:04 (IP=192.168.1.86) RSSI=-64 Rate=72Mbps host android-ef6a34cff30cc76a
13:10:40 03 Feb. Receive a DHCP request
13:10:35 03 Feb.  5G   WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
13:10:31 03 Feb. NTP synchronization start
13:10:29 03 Feb. WAN connection PTM connected
13:10:28 03 Feb. PPP IPCP Receive Configuration ACK
13:10:28 03 Feb. PPP IPCP Send Configuration Request
13:10:28 03 Feb. PPP IPCP Receive Configuration NAK
13:10:28 03 Feb. PPP IPCP Send Configuration ACK
13:10:28 03 Feb.  5G   WiFi scan(Reason:boot)
13:10:28 03 Feb. PPP IPCP Receive Configuration Request
13:10:27 03 Feb. PPP IPCP Send Configuration Request
13:10:27 03 Feb. PPP CHAP Receive success : authentication successful
13:10:27 03 Feb.  2.4G WiFi auto selected channel 11 Bandwidth:20M(Reason:boot)
13:10:27 03 Feb. PPP CHAP Receive Challenge
13:10:27 03 Feb. PPP LCP Receive Configuration ACK
13:10:26 03 Feb. PPP LCP Send Configuration ACK
13:10:26 03 Feb. PPP LCP Receive Configuration Request
13:10:26 03 Feb. PPP LCP Send Configuration Request
13:10:23 03 Feb.  2.4G WiFi scan(Reason:boot)
13:10:11 03 Feb.  2.4G WiFi auto selected channel 11 Bandwidth:20M(Reason:boot)
13:10:07 03 Feb.  2.4G WiFi scan(Reason:boot)
13:10:06 03 Feb.  5G   WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
13:10:01 03 Feb.  5G   WiFi scan(Reason:boot)
13:09:55 03 Feb. DSL Link Up: Down Rate=44000Kbps Up Rate=10000Kbps; SNR Margin Down=9.1dB Up=11.1dB
13:09:48 03 Feb. Booting firmware v0.07.06.01239-BT (Mon Jan 23 17:38:22 2017)
13:09:48 03 Feb. System start Button press (PowerButton)
13:09:38 03 Feb.  5G   WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
13:09:31 03 Feb. System up
13:09:30 03 Feb.  5G   WiFi scan(Reason:boot)
13:09:15 03 Feb.  2.4G WPS feature enabled
13:09:15 03 Feb.  2.4G WPA2 mode selected
13:09:15 03 Feb.  2.4G WiFi  UP
13:09:15 03 Feb.  5G   WPS feature enabled
13:09:15 03 Feb.  5G   WPA2 mode selected
13:09:15 03 Feb.  5G   WiFi  DOWN
13:09:14 03 Feb. IPv6 Service: DHCP Server stop
13:09:14 03 Feb. IPv6 Service: RA Server stop
13:06:44 03 Feb. Device Connected: 192.168.1.148 18:65:90:50:df:34 Stevens-iPhone
13:06:44 03 Feb. 2.4G Client associate from 18:65:90:50:df:34 (IP=192.168.1.148) RSSI=-73 Rate=28Mbps host Stevens-iPhone
13:06:42 03 Feb. Receive a DHCP request
13:06:05 03 Feb. Device Disconnected: 192.168.1.118 40:b3:95:3a:53:8a iPhone
13:05:13 03 Feb. Device Disconnected: 192.168.1.148 18:65:90:50:df:34 Stevens-iPhone
13:05:06 03 Feb. 2.4G Client diassociate from 18:65:90:50:df:34  (IP=192.168.1.148) RSSI=-81  Rate=52 Mbps
13:02:12 03 Feb. Device Disconnected: 192.168.1.242 64:20:0c:35:55:f2 Kids-iPad
13:02:09 03 Feb. Device Disconnected: 192.168.1.196 6c:40:08:b1:d5:4c Sophies-MBP
13:02:02 03 Feb. 2.4G Client diassociate from 6c:40:08:b1:d5:4c  (IP=192.168.1.196) RSSI=-66  Rate=52 Mbps
12:56:40 03 Feb. Device Connected: 192.168.1.242 64:20:0c:35:55:f2 Kids-iPad
12:55:23 03 Feb. Device Disconnected: 192.168.1.92 88:c6:63:88:c3:0b Steves-iPod
12:51:57 03 Feb. 2.4G Client associate from 8c:fa:ba:a9:a1:31 (IP=192.168.1.245) RSSI=-59 Rate=65Mbps host
12:51:55 03 Feb. Receive a DHCP request
12:50:15 03 Feb. Device Disconnected: 192.168.1.87 0c:51:01:7d:d8:19 iPhone
12:48:45 03 Feb. Device Connected: 192.168.1.139 a8:88:08:b6:d8:9d iPad
12:44:40 03 Feb. Device Connected: 192.168.1.92 88:c6:63:88:c3:0b Steves-iPod
12:44:40 03 Feb. 2.4G Client associate from 88:c6:63:88:c3:0b (IP=192.168.1.92) RSSI=-78 Rate=5Mbps host
12:44:39 03 Feb. Receive a DHCP request
12:43:14 03 Feb. Device Disconnected: 192.168.1.242 64:20:0c:35:55:f2 Kids-iPad
12:41:39 03 Feb. Device Connected: 192.168.1.87 0c:51:01:7d:d8:19 iPhone
12:40:17 03 Feb. Device Disconnected: 192.168.1.87 0c:51:01:7d:d8:19 iPhone
12:39:36 03 Feb. Device Connected: 192.168.1.196 6c:40:08:b1:d5:4c Sophies-MBP
12:39:36 03 Feb. 2.4G Client associate from 6c:40:08:b1:d5:4c (IP=192.168.1.196) RSSI=-66 Rate=24Mbps host Sophies-MBP
12:39:35 03 Feb. Receive a DHCP request
19 REPLIES 19
m0sbf
Message 2 of 20
Re: Hub 5B re-boots every 4 to 5 days
Another disconnection. The hub never made it to 4 days without another re-start. Please, someone any ideas what is causing all these disconnections:
17:51:46, 07 Feb.CWMP: HDM socket opened successfully.
17:51:42, 07 Feb.CWMP: Server URL: https blah blah; Connecting as user: ACS username
17:51:42, 07 Feb.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
17:51:42, 07 Feb.CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:51:17, 07 Feb.NTP synchronization success
17:51:03, 07 Feb.NTP synchronization start
17:51:01, 07 Feb.WAN connection PTM connected
17:51:01, 07 Feb.PPP IPCP Receive Configuration ACK
17:51:01, 07 Feb.PPP IPCP Send Configuration Request
17:51:01, 07 Feb.PPP IPCP Receive Configuration NAK
17:51:00, 07 Feb.PPP IPCP Send Configuration ACK
17:51:00, 07 Feb.PPP IPCP Receive Configuration Request
17:51:00, 07 Feb.PPP IPCP Send Configuration Request
17:51:00, 07 Feb.PPP CHAP Receive success : authentication successful
17:50:57, 07 Feb.PPP CHAP Receive Challenge
17:50:57, 07 Feb.PPP LCP Receive Configuration ACK
17:50:56, 07 Feb.PPP LCP Send Configuration ACK
17:50:56, 07 Feb.PPP LCP Receive Configuration Request
17:50:56, 07 Feb.PPP LCP Send Configuration Request
17:50:26, 07 Feb.DSL Link Up: Down Rate=44000Kbps, Up Rate=10000Kbps; SNR Margin Down=9.1dB, Up=11.2dB
17:49:57, 07 Feb.DSL Link Down: duration was 362479 seconds
17:45:56, 07 Feb.WAN connection PTM disconnected
17:45:52, 07 Feb.PPP LCP Send Termination Request (User request)
17:45:49, 07 Feb.PPP LCP Send Termination Request (Peer not responding)
17:15:58, 07 Feb.2.4G Client diassociate from 28:16:ad:55:18:0b (IP=192.168.1.151) RSSI=-51 , Rate=52 Mbps
16:29:29, 07 Feb.Tunnel is down
16:14:14, 07 Feb.Tunnel is up
16:08:20, 07 Feb.2.4G Client associate from 28:16:ad:50:f2:53 (IP=192.168.1.174) RSSI=-48, Rate=6Mbps, host DESKTOP-CHI5BQH
16:07:07, 07 Feb.2.4G Client diassociate from 40:b3:95:3a:53:8a (IP=192.168.1.118) RSSI=-55 , Rate=52 Mbps
imjolly
Message 3 of 20
you didn't say what you have tried in an attempt to solve the disconnections
can you post router stats please
are you currently using test socket with a filter?  if so have you checked that there is no dial tone at all your extension sockets whether in use or not?
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
m0sbf
Message 4 of 20
Thanks @imjolly
I have a dedicated 2nd phone line, which has no extensions connected to it. It's not a socket that you can take the front off, for that reason. There is a microfilter connected and I have changed this a few time, with no discernable improvement in reliability. I did a quiet line test and the line was silent. Of course, that doesn't mean that some noise burst on the line doesn't happen once every few days. I will repeat a quiet line test for a longer period and report back.
I have a brand new TP Link VR900 v2 here which I might connect this afternoon, if I get time. Although the line hasn't been up for 24 hours, so I don't know whether another WAN disconnection (with me commissioning the new router) within the same 24 hour period is wise? The TP Link is supposed to be pretty reliable, so it remains to be seen whether it improves things.
Here are the stats from the HH5, which show a banded 44MB/10MB profile that I am trying to remove, but the WAN connection drops every few days so the DLM counters will never allow rate increases, as it stands. Hence I may try the TP Link for a while:
1. Product Name: HomeHub5
2. Serial number: +076286+1532009269
3. Firmware version: v0.07.06.01239-BT (Type B) Last updated 12/5/2017
4. Board version: 01
5. VDSL uptime: 0 days, 20:20:48
6. Data Rate: 10000 / 44000
7. Maximum Data Rate: 17155 / 54485
8. Noise Margin: 11.7 / 9.3
9. Line Attenuation: 27.9 / 19.8
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 233.0 MB / 5.0 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-JG72
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-JG72-5G
19. 5GHz wireless connections: Disabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 5c:dc:96:c5:8d:46
24. Software variant: -
25. Boot loader: 0.5.1-BT (Wed Nov 12 11:52:05 2014)
imjolly
Message 5 of 20
so unlike most beople you have a separate line for your fibre connection so no problems with wiring
if you switch to the tplink then go into hub and disconnect internet from there rather than just unplugging or switching off power
m0sbf
Message 6 of 20
Thanks @imjolly
Yes, I have a dedicated line with separate wiring for broadband. I have a dedicated BT line box in my office. In the old days of ADSL this gave me 8.5MB connection, whereas the other line to this house (with extension wiring from the faceplate) barely gave me 3MB.
I'll see if I can find time to fit the TP Link today. If not, it will be done imminently. Thanks for the tip about internet disconnection from the hub. Does the DLM see that as a requested disconnection, rather than a failure of service?
imjolly
Message 7 of 20
basically it is just the hub and a controlled shut down as against a sudden loss of connection
m0sbf
Message 8 of 20
m0sbf
Message 9 of 20
@imjolly If you're interested, the TP Link VR900 v2 is now installed. Very easy to set up (5 minutes). Seems to be working well on BT VDSL2. WiFi performance is better than the HH5B. 5GHz is particularly good; in some extremities of the house it's stronger than 2.4GHz, which is odd.
A laptop the other side of the house gave 40MB download speed on 5GHz, so it looks pretty decent.
HH5B Max data rate before swap: 16522 / 54519
TP Link VR900 v2 after swap: 16481 / 57923
Actual Rate (banded as the same) - so there is no actual data speed increase: 10000 / 44000
S/N Ratio HH5B: 11.7dB / 9.3dB
S/N Ratio VR900 v2: 11dB / 9.8dB
I can't see any VDSL uptime status on the VR900 and line stats are very basic. I'll have to ask their tech team as I want to keep an eye on WAN stability. I don't want my line banded any lower due to disconnections.
The unit runs just slightly warm and power consumption doesn't look that dissimilar to the HH5B.
imjolly
Message 10 of 20
Sounds good so far hope that continues
