ithebebs
Message 91 of 123
Re: Hub 6 not connecting to VPN
I would say the BT router pips the VR900 for simplicity but the VR900 is still very easy to set up. The port forwarding was easy enough to figure out...
oldforger
Message 92 of 123
Hellloooooo? If there is a moderator monitoring this thread please could you post a note at least confirming that the issue is being actively investigated. If not I will be seeking a refund and looking elsewhere for a router. Doubtless this will be involve hassle and time wasted so keen to avoid it if possible. Thanks.
nix99
Message 93 of 123
+1
MonkeyWonders
Message 94 of 123
I'll be looking to return my hh6 and get a refund soon. Has anybody else done this?
sevenacregreen
Message 95 of 123
As I was on to BT today to renew line rental contract had another go at the support route. Asked if I could return the hub as I felt it was not fit for purpose. Outcome replacement hub being sent. Doubt it will fix it but will try it when it arrives.
Problems I am having are the w10 vpn reboot and drop out of devices both on wired and wireless. I find that I lose Internet on wired w10 machine while still seeing local network devices. Pc restart does not fix it but hub reset restores Internet. Internet is working on WiFi from phone during this problem.
Trying to avoid spending on an alternative router.
nix99
Message 96 of 123
Reading between the line it's possible you're experiencing the duplicate IP issue (i.e. two machine being handed the same IP).
Really hope a new router fixes your issue but I'm 99.9% sure it's a firmware problem so changing the hardware will make no difference.
sevenacregreen
Message 97 of 123
I suspect it won't fix it but interesting they offer a replacement rather than the fob off I have had in the past.
oldforger
Message 98 of 123
Is there a thread anyone could point me to for the duplicate ip issue because I am also suffering from this but it has been a secondary annoyance to the VPN disaster for me and I have got round the problem by manually re-assigning IP addressess every time I wake my main machine up from sleep.
The more I read about this piece of kit (HH6) the more I feel it needs some fairly major re-engineering.
smf22
Recognised Expert
Message 99 of 123
It's probably in one of the 170 odd posts in the thread BT Smart Hub (Home Hub 6) Bug Reporting + Improvements, but without going through them all I can't point you at anything specific.
I might be wrong, but I seem to remember a statement in one of the posts that said changing the size of the DHCP scope from the default of 192.168.1.63 - 192.168.1.254 had resolved the issue. I've always reduced the DHCP scope size as I want more static IP and have never seen this DHCDP issue so it might be worth giving it a go.
Regards
oldforger
Message 100 of 123
reply to smf22
Thanks for this, I ll look into it.
