Message 1 of 6
Hub 6 trying to update
Sins the smart hub updated to Firmware version: SG4B10002244 its trying to look for a newer update about 2 in the morning every day and then restarts.
Is this normal? Thanks
5 REPLIES 5
Recognised Expert
Message 2 of 6
Re: Hub 6 trying to update
If you're seeing some TR69 activity this could simply be 'periodic' where the Hub connects back to the ACS every 24 hours to pass back usage data etc. TR69 is not only used for firmware distribution.
Can you post the messages from the log?
Regards
Message 3 of 6
@djstevied
You can filter the event log to show only TR69 events, it saves going mad with all the entries Smiley Wink
Message 4 of 6
There is daily TR69 activity but the Hub should not restart.
Message 5 of 6
Ive attached a copy of the Log bellow. Thanks
Error log
Message 6 of 6
Just happened again. Same time as yesterday.
01:55:16, 24 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
01:55:14, 24 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
01:55:14, 24 Dec.
InformResponse:TR69 receiving (c]C�î�u���A����p message
01:55:13, 24 Dec.
ppp1:TR69 event found : M Reboot
01:55:13, 24 Dec.
ppp1:TR69 event found : 4 VALUE CHANGE
01:55:13, 24 Dec.
ppp1:TR69 event found : 1 BOOT
01:55:12, 24 Dec.
ppp1:TR69 sending Inform message
01:55:12, 24 Dec.
01:55:12, 24 Dec.
01:55:12, 24 Dec.
01:55:11, 24 Dec.
01:55:09, 24 Dec.
ppp1:TR69 creating new session with ACS
01:50:39, 24 Dec.
01:50:39, 24 Dec.
:TR69 sending RebootResponse message
01:50:39, 24 Dec.
Reboot:TR69 receiving message
01:50:38, 24 Dec.
01:50:38, 24 Dec.
InformResponse:TR69 receiving message
01:50:38, 24 Dec.
01:50:38, 24 Dec.
ppp1:TR69 event found : 2 PERIODIC
01:50:37, 24 Dec.
01:50:36, 24 Dec.
01:50:36, 24 Dec.
01:50:35, 24 Dec.
01:50:35, 24 Dec.
