conrad
Recognised Expert
Message 1 of 4
Hub usage figure - does this include FON/OZ?
This is kinda linked to other threads as well.
My hub data shows 0.6gb in the last 22hrs which in total is probably correct but 90% of my activities have been on FON/OZ .
(data sinceHub  reset)
My BT usage quoted is what I expect given the split between BB and FON this month.
This is the first time I have looked at the actual Hub figure and just want to know as I have definitely not downloaded that amount of data whilst connected to the home hub
3 REPLIES 3
Message 2 of 4
Re: Hub usage figure - does this include FON/OZ?
The hub figure will include FON, as its simply a measure of data passed between the hub and the Internet.
conrad
Recognised Expert
Message 3 of 4
Have just checked BT usage monitor which changed by what I was expecting.
I have been at home using FON so assume that this is why hub is picking it up. Will hub still record usage if I access FON out and about - this would mean comparing hub to BT monitor is irrelevant.
Thanks for the help Keith.
Message 4 of 4
FON usage out and about does not count against your usage.
The data recorded by the home hub does not accurately reflect usage, as other people could also use your BT wifi (FON) hotspot, and that would be recorded by the hub as well.
