Message 1 of 4
Hub3 firmware question.
What is the latest firmware which my BT Hub3 should be using?
Currently:  version 4.7.5.1.83.8.94.1.52 (Type A)
Last updated: 13/08/16
Todays date: 13/01/18
Hub is permanently on.
It seems to be quite a long time since any update, so I'm trying to find out if there is a problem with updating or whether I'm  using latest.
3 REPLIES 3
Message 2 of 4
Re: Hub3 firmware question.
that looks like latest firmware for 'A'  firmware updates automatically when you leave on 24/7 - there is no manual update available
Message 3 of 4
If that is the latest firmware update then at least I know it is not a problem with updating. Thanks for your prompt help.
Message 4 of 4
Just to confirm that this is the most current firmware and also that given the age of the HH3 I suspect there will never be any future updates. Which in many ways could be a good thing 🙂
