Message 1 of 3
Hub4 and EPSON printer wi-fi
I really hate wi-fi printers. Works one day and not the next.  Solved by turning hub4 off/on (which itself takes ages).
Is there a general fix?  IE turn off smart setup?  Or do I go straight to static a IP address?  Thanks.
2 REPLIES 2
Message 2 of 3
Re: Hub4 and EPSON printer wi-fi
Never had any problems personally.
Certainly turn off Smart Setup, if that doesn't help you could try giving the printer a static IP on the printer itself.
Message 3 of 3
as you have a HH4 then split networks and connect the printer to 2.4ghz network
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
