Jenni52
Message 1 of 2
Hub5 connection
I have 1 friend who cannot connect his smartpho e to my hub any ideas please?
1 REPLY 1
Liam_
Recognised Expert
Message 2 of 2
Re: Hub5 connection
Depends on the device.  There might be a compatibility issue, assuming of course the details being used for the connection are correct.  You could try one and only one, factory reset of the hub and see if that fixes the issue.  Failing that you might consider trying a third party router, they don't need to be expensive, like this for example.
TP Link TD-W9970
Available online for £30 inc delivery.  Amazon.
