Travelusa
Expert
Message 1 of 7
Hub6 firmware issues
I reinstalled my hub 6 as was made aware of new firmware
on installing the new 2244 firmware installed
it appears to have stopped my rebooting
but my ip profile have not improved after dropping down to 40mb from 74mb
on looking at the info screen
it say my line can do
27 mb upload with 91mb download that is the max reading
but only getting
15mb upload and 44mb download
My ip profile b4 all the issues with the 223e firmware was 74.1
noise levels are upload  13.1 and download is 18.8 that appears to have increased with new software
line atten is 15.8
I have done a full factory reset
but that appears not to have done anything
Any Ideas out there apart from changing to another router ??
6 REPLIES 6
Distinguished Expert
Message 2 of 7
Re: Hub6 firmware issues
but only getting
line atten is 15.8
Are you sure that the full factory reset was performed?
It's possible that it just performed a reset.
The reason for suggesting this was that mine would not factory reset (or even reset) from the recessed button - it was inactive, after the 2244 update. Whether this was a temporary situation remains to be seen......
You can do a factory reset from the humhub manager page: but do it by ethernet connection, otherwise, if you have changed your wireless key, then it's more time to connecting afterwards.
Travelusa
Expert
Message 3 of 7
Yep did it via the menu
Selected the Factory reset
problem is it appears to have reloaded the firmware as the date has changed again.
took 5 hrs for the hub to start again appears started at 2am this morning
profile still the same
Travelusa
Expert
Message 4 of 7
Mods I Need your Help Please
I was one of the people that had issues withe the smart hub 6a firmware 223e
Resetting every 2 to 3 hrs knock out my ip profile
swapped over to my old hub 5a ??????
noticed message about new hub6a firmware so reinstalled my hub6a git the new firmware 2244
but that appeares to have issues as well .....justgoes offline and take over 4 hrs to pick up again
did a factory reset and it still dows it
So have gone back to my hib 5a and also gone onto the test socket
my speed has dropped from 74 mb to just on 33 mb on the infor screen
Test Result
Download speedachieved during the test was - 31.83 Mbps
 Additional Information:
 IP Profile for your line is - 32.4 Mbps
Test Result
Upload speed achieved during the test was - 7.57Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
 So i show 32.4 download and 7.57 upload
I did have b4 the hub 6 issues almost 74 mn download  with 19mb upload
6. Data rate: 9542 / 33478
7. Maximum data rate: 25445 / 81017
8. Noise margin: 16.9 / 19.6
9. Line attenuation: 19.1 / 15.5
10. Signal attenuation: 19.0 / 15.5
according to the max spped i should be near the 76 mb
I think the noise margin of 19.6 could be the issue due to all the resets
How can that be brought back down
Its got to the point that the BTTV on HD is getting blocky now
Should i be asking for a refund as i pay for infinity 2 but getting below infinity 1
Is there a better alternate router to the Hub 6a
that not have so many issues
I brought the hiub6a like evryone else as part of the discounted launch so would BT Replace it
Message 5 of 7
Re: Mods I Need your Help Please
Just leave he hub 5 connected and providing you can maintain a stable connection the DLM should release the connection within a couple of weeks you will not get a refund for DLM action as to other router just read through thee forum you will see that question is asked regularly
Travelusa
Expert
Message 6 of 7
Trouble is the bt software caused all the issues with no sorry we cocked up from them
so we have for suffer for bad service
Message 7 of 7
The difficulty in the HH6 connecting, and the low profile, could be caused by noise on the phone line.
The fact that you are also getting breakup on HD BTTV, even with plenty of bandwidth for HD, (31Mbs), would point to a high error rate on your line.
I believe single HD channel only requires about 9Mbs . Even if you are also recording one, that is only 18Mbs, however because there is no error checking on multicast, then any errors will affect the picture, the more errors, the more it will be noticed.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
PS I merged his thread with your existing one which was still unsolved, to avoid any duplication.
The mods have so control over DLM
