RayP
Message 1 of 18
Huge drop in 5Ghz download speed every 3-4 days
I have had the HH5 router for a few years but have only recently started using the 5GHz wireless option for several devices including an iPad, Windows 10 laptop and smart TV.
I have separated the 5Ghz SSID from the 2.4Ghz one and have refreshed the channel selection (it's on automatic) but it continues to use Channel 36. There are no other neighbours within a reasonable distance using the same channel.
The download speed will drop from 66Mbps down to 14Mbps every 3-4 days and I have to perform a reset on the router to get the original speeds back. I don't think having to do this every 3-4 days is acceptable.
Do these problems exist with the latest Home Hub? If they don't then I've a reasonable case for a free upgrade. Would you agree?
17 REPLIES 17
gg30340
Message 2 of 18
Re: Huge drop in 5Ghz download speed every 3-4 days
Setting aside your wireless problem, I would not class the Smarthub 6 an "upgrade". It does nothing more/better than  the HH5 does and it does not come without its own problems. Have a look through the forum.
You would be far better to spend some of your hard earned cash on a decent third party VDSLModem/router and replace the cheaply produced for the masses ISP router.
imjolly
Message 3 of 18
@gg30340 I disagree and having used a couple of hh6 since inception the wireless gave me better coverage than HH5 but apart from that little difference
gg30340
Message 4 of 18
Would you class it as an "upgrade" or just a newer model?
imjolly
Message 5 of 18
@gg30340  difficult newer model with an upgraded wireless
gg30340
Message 6 of 18
Haha very diplomatic.
RayP
Message 7 of 18
I'm not adverse to buying an independent but it does seem to be getting BT off the hook. Anything you can recommend and given I'm no network expert how dificult are these things to configure compared to the BT one?
RayP
Message 8 of 18
Thanks for your reply. The wifi speed is excellent after a reset and for a couple of days. Does the HH6 share the same problem? If so then it seems pointless staying with BT kit although Which? has awarded the HH6 Best Buy status.
imjolly
Message 9 of 18
the hh6 hubs which I used did not give me any wireless problems once I split the networks and selected my channels manually
many use the tplink 9970 which is cheap £35/40 and from reports works well for a single banded router
RayP
Message 10 of 18
Thanks for the recommend. I think I'll do as you did and set the channels manually rather than use the auto mode. If the problem persists then I need to make a decision. But I need 2.4 and 5 as some kit doesn't work on 5.
