Message 1 of 2
Hybrid Connect - attaching additional antennas
hi there,
did see a thread where people were attaching antennas to the hybrid connect.
Can anyone recommend or link my to antennas that have proven to work?
I've had two attempts now with SMA Male with PIN antennas but they don't seem as big as some of the photos on the other threads.
If anyone can help would be really grateful.
Many thanks
TECHHERO
1 REPLY 1
Message 2 of 2
Re: Hybrid Connect - attaching additional antennas
These fit, but as posted on another thread, the signal strength is better without them than with. They have SMA connectors so not sure why the ones you tried didn't fit.
4G LTE Antenna, 10dBi SMA Antenna (2 Packs) Omnidirectional Huawei Antenna 16cm for 3G/4G LTE Modem Router Mobile Hotspot wifi camera Huawei B525, B612, B593, Vodafone, TP-Link MR400, ZTE MF283 286
