TomDowns15
Message 1 of 10
I Need A New BT Home Hub 5
Hello,
I need a new BT Home Hub 5 as mine has just broken and instantly I can tell that the signal has gone down dramatically and the wireless isn't as strong. I've unplugged everything and I shake it a little and it sounds as if there is a part loose and rattling about. Where can I request a new hub?
Thank you.
Tags (1)
9 REPLIES 9
Message 2 of 10
Re: I Need A New BT Home Hub 5
You will need to report a fault at  0800 111 4567
TomDowns15
Message 3 of 10
Is it possible to do it online?
wedd1ng528
Message 4 of 10
Probably only if one of the mods pick up on your post but hey! it's a freefone number and much quicker than waiting for a mod to reply then you have to fill in a form etc etc.
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
Message 5 of 10
No, you will have to report a fault. They will get you to carry out tests to ensure that the hub is faulty and only if it is will they then send a new one out to you. If you are still in contract this will be free but if your contract is ended you will either have to pay for a new one or re-contract.
TomDowns15
Message 6 of 10
Yeah I'm still in contract with them. Personally I think that my hub got damaged in transit like in the post so I need a new one.
Message 7 of 10
then phone CS using number already posted
Message 8 of 10
So how come in your first post you said "mine has just broken and instantly I can tell that the signal has gone down dramatically and the wireless isn't as strong".
If it was broken in the post I would have expected it to be like that from the start.
As said, you will need to report a fault. They don't just hand out new ones because the customer says it broken, they need to test it.
vofsanity2
Recognised Expert
Message 9 of 10
Yes you can report the fault online here : -
https://bt.custhelp.com/app/contact_email/c/5627,5629
TomDowns15
Message 10 of 10
Already had one sent out to me haha thanks for all the help guys 🙂 a new home hub 5 is on its way to me
