MarkConway
Newbie
Message 1 of 2
I have very poor wifi coverage from my BT smart hub. I want to use a 2nd router to extend the range.
I have very poor wifi coverage from my BT smart hub. I want to use a 2nd router to extend the range. Does the Smart Hub 6 support bridging or repeating mode?
1 REPLY 1
V_Meldrew
Recognised Expert
Message 2 of 2
Re: I have very poor wifi coverage from my BT smart hub. I want to use a 2nd router to extend the ra
No.
There are other options such as powerline adapters which also double up as wifi hotspots  (e.g. BT Home Hotspot 600), wifi extenders, tagging on an old wireless router as a wireless AP or, probably the best method, replace the Smarthub with a decent 3rd party router
