Hi, I just got complete wifi with a wifi disc but should I be seeing the disc as a separate connection?
I've synched the disc and the router and moved the disc upstairs but my connection never moves from the one original router connection. I just wanted to check if this is right, or should the disc create another connection that I should connect to when I am upstairs?
No, the disc does not present as a seperate network.
Check the status of the disc using the MyBT app as follows.
Open the MyBT app.
Tap More (bottom Right Hand corner)
Tap "Your wifi network"
You should see your hub and disc presented in graphical form
Great thanks!
