Message 1 of 5
I really need some help on multiple issues please. (FIFA Online Gaming Consistency)
Hi everyone
I'm having trouble with my gaming experience on FIFA 23 on Playstation 5. I'm using a wired connection.
I've got issues with inconsistent gameplay via input delay / lag.
I've taken action on the following
Opened Ports for FIFA
Opened Ports for PS5
Set up a Static IP address for my PS5
DMZ - On
Tested Disabled all Firewalls (now been put back on)
Played the game off peak hours
New Controller
I've now removed all open ports as nothing changed
I've now set the internet connection to AUTO and removed the static IP as no change.
I've just noticed that my WIFI is set to - Public Hot Spot Active
I have no way of switching this off via my Router or I can't find it anyway. I notice I get random devices on my wifi network and unsure if this is causing the issue.
I'd also like to have my NAT TYPE to OPEN.
It's currently set to NAT TYPE 2
I've spoken with EA Sports countless times on previous editions of the game 19, 20, 21, 22 and they always say it's an ISP issue. My ping when joining a game is always shown as between 10-24ms
My PS5 connection is usually 300mb+ download and around 50-70mb upload.
I'm honestly going crazy with it. I've seen lots of other players complain about the same thing however lots of other people are having no issues at all.
I'm thinking of buying a gaming router but unsure if this will resolve the issue.
Any help would be much appreciated. I've had this problem for a long time.
Cheers.
4 REPLIES 4
Message 2 of 5
Re: I really need some help on multiple issues please. (FIFA Online Gaming Consistency)
Are you a BT Retail broadband customer and if so which broadband connection do you have FTTC or FTTP.  which router are you using?
Message 3 of 5
Firstly thank you for your reply.
On my router management it says my connection type is External FTTX
I'm not sure what you mean by retail customer Sorry.
Message 4 of 5
Who supplies your Broadband?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 5
BT
