Ihaveapigeon456
Message 1 of 41
I tried to move my router upstairs to get better signal but it didn’t work
The other day i tried to move my router upstairs from downstairs to get better signal but this didn’t work and the router light was orange and the broadband light was red. I think this was due to the socket upstairs not being a master socket but I’m not sure. If you can help please comment.
40 REPLIES 40
licquorice
Message 2 of 41
Re: I tried to move my router upstairs to get better signal but it didn’t work
Does your downstairs socket look like this?
Image result for ssfp
If so, the upstairs socket will be filtered and won't work without rewiring the master differently.
imjolly
Message 3 of 41
Does your master socket have 2 outlets - 1 for hub and 1 for phone?  If so your hub will only work in your master socket unless you change the wiring. Moving to an extension socket if you could connect hub may well result in a drop in connection speed
Ihaveapigeon456
Message 4 of 41
To answer both of your questions. The master socket does not have 2 ports but has 1 and the upstairs socket had 2 ports side by side.
Ihaveapigeon456
Message 5 of 41
imjolly
Message 6 of 41
can you post pic of upstairs socket
Ihaveapigeon456
Message 7 of 41
I have multiple sockets around the house I have tried all of them and they all don’t work they look like this.
https://mega.nz/#F!gmgx1CLC!rGjYLhYJRcyTZ88XQ9KX3A
imjolly
Message 8 of 41
your link does not work for me
can you see where the openreach cable enters your home from outside?  if so is there a socket there which is normally the master socket
licquorice
Message 9 of 41
I suspect your whole wiring is a complete bodge and needs investigating and rewiring properly. Photos of the connections behind every socket might help us to figure out how it is wired.
Ihaveapigeon456
Message 10 of 41
