imjolly
Message 11 of 41
Re: I tried to move my router upstairs to get better signal but it didn’t work
neither links work for me
did you check where openrach cable enters your home and if there is a socket there
Ihaveapigeon456
Message 12 of 41
Yes the cable leads where the router is
imjolly
Message 13 of 41
sorry but is that at the downstairs socket?  if so as @licquorice said you have a problem with your internal wiring and need s sorted out if you want to move hub to another socket
you could get openreach or get a local telecom person far cheaper
licquorice
Message 14 of 41
There doesn't appear to be a picture of the master (single) socket. Can you post a picture showing not only the connections but the cables.
Ihaveapigeon456
Message 15 of 41
I will do that tomorrow because the master socket cables are outside and it is a bit dark outside
Ihaveapigeon456
Message 16 of 41
@imjolly yes that is the downstairs socket
imjolly
Message 17 of 41
If your wiring is ok and the downstairs socket is master then your router should work basically in any socket but speed may be less than you get in the downstairs master socket. As router does not work upstairs it points to wiring problems
licquorice
Message 18 of 41
As the three extension sockets only appear to have one cable each, I suspect they were star wired from a junction box and have been disconnected to prevent them causing problems with the broadband at the master socket.
Ihaveapigeon456
Message 19 of 41
yes I just checked and it is star wired from a junction box here are the photos.
https://drive.google.com/open?id=1-7Yo2MNybFr4yHE6VouuzY6FEDPA4kaU
CJT80
Recognised Expert
Message 20 of 41
Hi there @Ihaveapigeon456
From the last link, the 2nd image (IMG_3084) is the master socket?  that's downstairs?
Just wanted to clarify.
EDIT: Also pic 1 is the faceplate to that master socket, and normally it should have the extensions wired to it.  That appears to be an issue.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
