licquorice
Message 31 of 41
Re: I tried to move my router upstairs to get better signal but it didn’t work
By pressing the wires into the insulation displacement connector with (ideally) the correct tool or failing that a very thin bladed screwdriver.
Ihaveapigeon456
Message 32 of 41
I have the tools for it.
Do I connect both of them to terminal 2 or 5 or one of them to terminal 2 and one of them to 5?
Please help
imjolly
Message 33 of 41
1 wire to 2 and other to 5
Ihaveapigeon456
Message 34 of 41
Ok
Ihaveapigeon456
Message 35 of 41
Connecting the wires didn’t work. I might have installed it wrong here is a picture of it
https://drive.google.com/open?id=1-Ax7POYc8WZM1VUcBuPwdFf-TXpXr9aj
licquorice
Message 36 of 41
Correctly wired. Did you replace the frontplate at the master before testing at the extension?
Ihaveapigeon456
Message 37 of 41
I did put it back but I didn’t think I plugged in the router correctly i will try it again and see if it works.
licquorice
Message 38 of 41
Plug a phone in and see if you get dial tone.
Ihaveapigeon456
Message 39 of 41
No it didn’t work I tried the router and telephone and the router flashed orange and the broadband light was red and the telephone said check telephone line. I don’t know what’s happening
licquorice
Message 40 of 41
It was just a long shot. You either need to get somebody in to sort you wiring out or go for plan B,  powerline adaptors.
