billyg
Message 1 of 8
IP Address
Hi,
I have just recently had Infinity installed in my home, but are having problems sourcing correct IP address for netflix on my Smart TV.
Would be grateful for any assistance as to resolve this issue.
Regards,
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: IP Address
Hi billyg,
Welcome and thanks for posting. Did you get this sorted yet? Can you post back and let us know how you're getting on? If you're still having problems I'm sure we'll be able to help.
Cheers
David
billyg
Message 3 of 8
Re: IP Address
@DavidM wrote:
Hi billyg,
Cheers
David
Hi David,
Unfortunately, I am still having difficulty connecting Smart TV as states cannot connect to Internet, with either check security key on Wireless Router(do't have one) as BT infinity and is IP  set correctly. I have been through various IP addresses, but can't get the TV to connect to internet, had no problem with previous provider.
Moderator-Retired
Message 4 of 8
Re: IP Address
Hi billyg,
I can take a look at your connection to see if anything is wrong. Can you send me in your details using the "Contact The Mods" link found in my profile and I will be in touch.
Thanks,
OlgaC
Message 5 of 8
Re: IP Address
@billyg wrote:
Hi,
Regards,
This is a very common problem which has been posted before on this forum.
There are a couple of help pages here, which may apply to your model of TV.
Samsung Smart TV
Panasonic Viera
You need to specify a static IP address as described, as the normal DHCP request is not recognised by the home hub, from those devices.
dilosec
Message 6 of 8
Re: IP Address
Switching Smart Setup off on the BT Home Hub will probably resolve problem.
See: http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
billyg
Message 7 of 8
Re: IP Address
Hi
Have just tried this, but no joy yet
billyg
Message 8 of 8
Re: IP Address
Thanks, took a little time, but now up and running
Very much appreciated all the replies
