Message 1 of 19
IP6
Does anyone here know who you contact at BT to get confirmation that their network can successfully route IP6?
18 REPLIES 18
Message 2 of 19
Re: IP6
No but I can confirm that BT's IPv6 implementation works absolutely fine.
My own Windows 11 kit doesn't usually use IPv4 these days.  Everything external seems to be routed as IPv6 and has been for a long time now.
Message 3 of 19
Re: IP6
Despite WSH’s experience. BT seem not to have fully addressed the IPv6 routing issue. Their consumer broadband rollout is still dependent on IPv4, and IPv6 support seems inconsistent across their infrastructure. My BT Smart Hub setups advertise IPv6 locally, but the addresses are link-local or ULA (unique local), meaning they don’t route properly to the wider internet. This leaves us customers with the appearance of IPv6 capability but no functional end-to-end connectivity.
My BT’s Smart Hub 2 show IPv6 addresses in Windows and router status pages.
However, the addresses are non-global (e.g., starting with fe80::, fc, or fd ), which cannot be used for public internet routing.
As a result, some  Microsoft applications, like GetHelp.exe, fail when trying to connect over IPv6, even though the system reports IPv6 is “enabled.”
At the moment the tech folk at BT tell customers who call for help that the problem is with their device and to re-boot it, use a different browser and clear their browser cache. It has nothing to do with the customer’s device, It is entirely a BT network issue. They should be honest and explain that BT hasn’t fully implemented IP6 yet (in spite of what they would like us to believe) and tell their customers to disable IP6 on their devices (there is no way for the customer to disable it on the Smart Hub). Once the devices use IP4 everything works again.
Better yet they could configure the Smart Hub to disable IP6 until they’ve got it sorted.
@whs Have you tried using gethelp.exe on your IP6 routed network?
Message 4 of 19
Re: IP6
Doesn't seem to be a problem.
IPv6 does use a link local for local traffic but you should also get a public IP if the IPv6 on the SH2 is configured correctly.
Message 5 of 19
Re: IP6
There are no user configurable items related to IP6 addresses on my Smart Hub. They are all set by BT.
Message 6 of 19
Re: IP6
Is that a Smart Hub or a Smart Hub 2?  It is certainly user configurable on the SH2, at least as to whether it is Stateless, Stateful or off
Message 7 of 19
Re: IP6
It's a SH2.
Allocation mode it set to "Both."
What should it be?
Message 8 of 19
Re: IP6
Doesn't really matter, but with Stateless IPv6 fine here
Message 9 of 19
Re: IP6
A quick test for IPv6 connectivity is https://loopsofzen.uk which is an IPv6 only site.
Message 10 of 19
Re: IP6
It’s difficult to gauge your level of experience, so forgive me if I’m stating the obvious here, but unlike IPv4 only the public prefix is supplied by the ISP.  I take it you appreciate that you’ll need to pass that to your devices by router advertisement and SLAAC if they are to get a functioning global address?
