crozza-9
Message 1 of 5
IPV6 and Nighthawk router
Anyone no how i go about setting up IPV6 on this router while still using IPV4, Wanting to use IPV6 for xbox,
Do i just use the same PPPOE settings? https://gyazo.com/d453f450fb8aa2fe4d26140d6456da95
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: IPV6 and Nighthawk router
Yes.
Message 3 of 5
I don't know if Netgear have changed their minds, but at one point they didn't support BT' s implementation of IPv6 of /56 PD and stated they had no intention of doing so.
crozza-9
Message 4 of 5
Thank you seems to have worked, Although is it normal for some websites not to work with ipv6?, Noticed Twitter and a few others don't load.
crozza-9
Message 5 of 5
After doing researching seems like you're right Netgear do not support BT ipv6
