PaulB67
Message 1 of 12
IPv6 LAN/WAN settings for TP-Link Archer AC5400
Hi.
Can anyone help with the settings i need for IPv6 on my router.
For LAN IPv6 - SLAAC/Stateless DHCP, it is asking for a prefix address, i cant get the IPv6 working on my Xbox One X through the TP-Link.
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: IPv6 LAN/WAN settings for TP-Link Archer AC5400
I assume you are using a separate modem in front of it, as the AC5400 is only a wireless router?
The home hub cannot be used as just a modem.
PaulB67
Message 3 of 12
I am using a vigor 130
Keith_Beddoe
Message 4 of 12
There is a thread which may be of interest https://community.bt.com/t5/Home-setup-Wi-Fi-network/IPv6-Global-Address-on-BT-Home-Hub-5/td-p/17636...
It discusses the prefix.
PaulB67
Message 5 of 12
Hi.
Read through that and a lot didnt make sense to me as a novice but i made some changes in my router but it still doesnt get an IPv6 address, pic below, any suggestions please...
Keith_Beddoe
Message 6 of 12
I think you may have to wait for a forum member who knows more about BTs implementation of IPv6.
PaulB67
Message 7 of 12
Ok, well thanks for your help Keith 🙂
licquorice
Message 8 of 12
A few things.
First of all make sure you have the latest version of firmware.
Second  change the setting to SLAAC rather than DHCP
Third, your device may not support BT's /56PD implementation of IPv6, my TD-W9980 didn't.
PaulB67
Message 9 of 12
Hi.
Changed to SLAAC (no diff), and it does have the latest firmware, i only installed it brand new on Friday last after checking it had the latest firmware (as does the Vigor 130)
I have online chatted with TP-Link support and they assure me it supports BT IPv6, just cant seem to get it to work, must be something within the settings, just cant sort it.
licquorice
Message 10 of 12
@PaulB67 wrote:
Hi.
Did they not tell you what settings they thought should work?
