Jamie_W
Message 1 of 4
IPv6 - What is it doing for me and should I enable it?
I'm on BT Infinity and I have just got myself an Asus DSL-AC88U router. I was going through the settings and have enabled IPv6, setting it to 'Native'. The other options I had available to me were Disable, Tunnel 6to4, Tunnel 6in4, Tunnel 6rd and Static IPv6.
Any tips on what this all means and if I should just leave it alone? Everything seems normal with it set to Native...
3 REPLIES 3
licquorice
Message 2 of 4
Re: IPv6 - What is it doing for me and should I enable it?
Native is correct setting
Liam_
Recognised Expert
Message 3 of 4
Everything will continue to work fine with IPv6 enabled.  Most devices will try to connect with Ipv6 first if possible.  Native setting is fine.
Jamie_W
Message 4 of 4
Thank you for the feedback!
