Liam_
Expert
Message 31 of 40
Re: IPv6 address available but no connection
@Reign_in_Beard
Things got crossed there.   Have you tried the latest firmware for your router?
If not then update it and perform a factory reset and re-enter your settings again.  They looked ok.  Just to reiterate:
Native
PPP
DHCP_PD Enable
Auto Configuration Setting Stateless
Connect to DNS Server automatically Enable
Enable Router Advertisement Enable
Reign_in_Beard
Message 32 of 40
Reign_in_Beard
Message 33 of 40
Yes tried all that Liam, think mine could be firmware but it’s running on the latest, and I can’t get it into recovery to try and force a downgrade
Liam_
Expert
Message 34 of 40
@Reign_in_Beard
Odd behaviour, some Asus models seem fine.  Are you using the same Asus router?  The RT-AC3200.
Might be another firmware bug.
Clutching at straws here, you might want to try different DNS servers rather than auto.  Assuming you don't do that already.
Try:-
208.67.220.220
208.67.222.222
IPv6:-
2620:0:ccc::2
2620:0:ccd::2
markgb
Message 35 of 40
The router model in question is DSL-AC88U. It's different to older Asus DSL routers as it uses a Broadcom chipset
Reign_in_Beard
Message 36 of 40
just tried the dns and still the same, when I run the test via http://test-ipv6.com i get No IPv6 address detected!
Tags (1)
Reign_in_Beard
Message 37 of 40
I have an 88U too
Liam_
Expert
Message 38 of 40
Sorry for the confusion guys, took the data from the wrong post.  Oops.
The issue is odd.  BT apparently got the intermittent IPv6 problem resolved.  So it shouldn't  be related.  This makes it more likely the firmware is still buggy.
A thought, is there anything that looks vaguely like 'Automatically negotiate a global address' in the Internet IPv6 settings?
markgb
Message 39 of 40
No I don't have anything like Automatically negotiate a global address
Liam_
Expert
Message 40 of 40
As nothing tried seems to help it looks like waiting for a firmware update is all that's left.  Unless you feel like returning it and swapping for a different model that is known to work with IPv6.
For example the one @Jonkarra   is using.  Just a thought.
