markgb
Message 11 of 40
Re: IPv6 address available but no connection
The behaviour has been the same with every version of the code I've tried including the factory shipped version. I'm now on a Beta version. I don't think the RT-88 is very common though so maybe no one has tried this version before
Liam_
Expert
Message 12 of 40
A quick look found a post on Kitz.  Seemingly Asus are still ironing out the firmware (as of May), not sure if they have a general release ready yet as you say you have a Beta,  so it's still looking like a firmware bug.  Soon, perhaps?
I think the most recent on the site is Version 3.0.0.4.382.15850 dated 29 August.
Reign_in_Beard
Message 13 of 40
Have you got this working? I have the same router and can’t get IPv6 working either
markgb
Message 14 of 40
Nope, not got it working yet. Haven't had a chance to look any further at it yet through. But I think I will flag it to ASUS when I get enough round tuits.
Reign_in_Beard
Message 15 of 40
I contacted Asus who just replied that it should be automatic and have I got the username and password input which I have. Bit frustrating as people with the same router seem to have it working. Was trying to downgrade to merlin firmware but can’t get the router in recovery mode at all
markgb
Message 16 of 40
I haven't seen anyone else with this router have it working - where did you see that?
What's merlin firmware?
markgb
Message 17 of 40
So the devices on my network seem to be getting three IPV6 addresses - link local and two public IPs, and the ::/0 route points to the link-local address of the gateway (shouldn't it be the 2a00:: public IP?)
Following dump is from a windows machine but I see two IPv6 addresses if I look on the settings screen of my Android devices too
C:\>netsh interface ipv6 show route
Publish Type     Met  Prefix                      Idx Gateway/Interface Name
No      Manual   256  ::/0                        6   fe80::6245:cbff:fe17:a0c0
No      System   256  ::1/128                     1   Loopback Pseudo-Interface 1
No      Manual   16   2a00:23c4:abcd:efgh::/56    6   fe80::6245:cbff:fe17:a0c0
No      Manual   256  2a00:23c4:abcd:efgh::/64    6   vEthernet (External)
No      System   256  2a00:23c4:abcd:efgh:20a5:rstu:383c:49d0/128 6 vEthernet (External)
No      System   256  2a00:23c4:abcd:efgh:9d36:wxyz:4842:cf9e/128 6 vEthernet (External)
etc.
Reign_in_Beard
Message 18 of 40
Merlin firmware is custom for the router, seems to be more stable if you google it, problem is the build number is lower, which you can only put on if your put the router into recovery mode, but try as I might I can’t get it
Liam_
Expert
Message 19 of 40
The data looks good.
You could check this site from a PC and see what the results are.  Just paste the first IPv6 address in the list and not the temporary one.
http://ipv6now.com.au/pingme.php
markgb
Message 20 of 40
The response for '2a00:23c4:c689:abcd:efgh:a7e3:4842:cf9e' using IPv6 is:
PING 2a00:23c4:c689:abcd:efgh:a7e3:4842:cf9e(2a00:23c4:c689:abcd:efgh:a7e3:4842:cf9e) 56 data bytes
--- 2a00:23c4:c689:abcd:efgh:a7e3:4842:cf9e ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4030ms
